Backing up data
- Backing up data
Backing up data
21-03-2015 9:01 AM
Re: Backing up data
21-03-2015 9:33 AM
You could set it up for example to do a complete backup once a week, and an incremental backup (eg what has changed) each day.
Acronis is a paid alternative which I used to use but it went through an awkward buggy patch so I abandoned it. I don't know what it is like now.
For data, a free cloud service like Dropbox, Google Drive or OneDrive works pretty well. I prefer Dropbox and am now paying for extra space, but it has the lowest quota of free space.
Re: Backing up data
21-03-2015 10:50 AM
It's a freeware download from http://www.techspot.com/downloads/6536-gigabyte-smart-recovery.html.
I have had need to use it and it works fine.
Re: Backing up data
21-03-2015 10:54 AM
Re: Backing up data
21-03-2015 10:58 AM
Re: Backing up data
21-03-2015 11:01 AM
Quote from: Strat Smart Recovery 2.
As described in the link above it does an initial full backup of the chosen drive to the chosen destination and then performs scheduled incremental backups.
I have used it to do a full roll-back of an initial OS install and also picked files from various dates going back 3 days.
Re: Backing up data
21-03-2015 11:15 AM
And rather more hidden in 8.1.
Quote from: HPsauce Windows 8 included a facility to take a full system image, though it's a bit hidden?
Control Panel, File History, bottom left corner.
Re: Backing up data
21-03-2015 11:32 AM
At present Acronis backs up the system drive and Sync Toy the data
However it is definitely a thought for the future when I do a rebuild
Re: Backing up data
21-03-2015 11:52 AM
What if my backup drive fails....I'll get another drive to back up the backup to...etc.
I currently have a System drive, a Data drive and a System Backup drive internally.
I also have a 3TB networked drive where data gets backed up to weekly with Sync Toy.
It was one of the best things I ever did long ago splitting system and data to separate drives.
Re: Backing up data
21-03-2015 1:22 PM
I would suggest you could put any and all personal files in a free cloud store like onedrive and use an external drive for the OS drive thus once the initial cost outlay has been made there is zero on-going costs associated with it (other than having the kit plugged in of course)
Re: Backing up data
21-03-2015 1:28 PM
Re: Backing up data
24-03-2015 10:59 AM
Quote from: sjptd One excellent free program is EaseUS backup: http://www.todo-backup.com/products/home/free-backup-software.htm That will back up OS, programs and data as a single (large) file. It does need quite a bit of space to backup onto.
I've opted to try this program. However how do I set it up to backup weekly and incremental backup daily please?
dick:green Quote fixed.
Re: Backing up data
24-03-2015 12:10 PM
The best free program out there is SyncBackFree. Be wary of Microsofts SyncToy as we had issues with that over a range of machines where it got it wrong and randomly deleted source files instead of backing them up. When comparing notes with other users they had periodically suffered the same and assumed it was something they had done by accident.
Stage 2 is to have both an external drive to regularly automatically back up to, plus, a portable external drive that is only connected to perform say a weekly manual backup. That way, if you pick up a ransomware issue then that data is safe as long as you don't connect it if you have an issue.
I've never relied on full system backups as I've heard stories. I remember a large number of users on Wilders forum who were regularly performing and verifying TrueImage full system backups. When they needed them in anger they were accually corrupt.
I've always said that any serious issues and I would reinstall from scratch and then apply my saved data.
Re: Backing up data
25-03-2015 4:10 PM
It isn't the clearest interface I am afraid. Assuming you are on 8.2,
Click Disk/Partition Backup ...
Set up what you want to backup and where.
Click the Schedule at the bottom left and that will open a dialog with various options.
Also probably click the Image-reserve strategy to control how many older backups are preserved.
