BTOR modem features on ADSL
NorthEasterner
Hi as you may know, In the past few days I have figured out how to unlock the BT modem. I have come across of it being compatible with any suppliers Fibre and ADSL services. I am aware of what it does on fibre but not sure what it does on ADSL if you have a router/modem combo wireless box? Whats the difference between the BTORMODEM and the router/modem combo
Jamie
Ex Plusnet Fibre customer. BT Infinity Customer using a BT Smart Hub. If you wish to say thanks, please click the thumbs up Thumbs Up
Fixes: 17
Re: BTOR modem features on ADSL
It's a modem that supports VDSL and ADSL protocols.
With a combined router & modem, you don't need a separate modem, and depending on the model, may not be able to use one.
NorthEasterner
Will it make speeds faster? And also I'm going to give it to my friend who's on virgin media national bb will this workHuh
Jamie
