BTOR modem features on ADSL
- Re: BTOR modem features on ADSL
23-02-2013 11:12 PM
Hi as you may know, In the past few days I have figured out how to unlock the BT modem. I have come across of it being compatible with any suppliers Fibre and ADSL services. I am aware of what it does on fibre but not sure what it does on ADSL if you have a router/modem combo wireless box? Whats the difference between the BTORMODEM and the router/modem combo
Jamie
Jamie
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up
2 REPLIES 2
24-02-2013 8:08 AM
It's a modem that supports VDSL and ADSL protocols.
With a combined router & modem, you don't need a separate modem, and depending on the model, may not be able to use one.
24-02-2013 9:25 AM
Will it make speeds faster? And also I'm going to give it to my friend who's on virgin media national bb will this work???
Jamie
Jamie
