BT v2091 router
- BT v2091 router
BT v2091 router
04-10-2007 5:52 PM
learner
Re: BT v2091 router
05-10-2007 1:13 PM
I don't know of any way an analogue phone can be used for VOIP, but no doubt someone else will tell us if there is.
There are dedicated VOIP phones that will work without a PC, and connect directly to a network port on the router (if I remember rightly).
Re: BT v2091 router
05-10-2007 1:17 PM
A dedicated VoIP phones, or a USB phone would be a much easier solution.
Re: BT v2091 router
07-10-2007 5:07 PM
Re: BT v2091 router
08-10-2007 1:29 PM
http://www.voip-info.org/wiki-VOIP+Phones
Re: BT v2091 router
08-10-2007 1:49 PM
1. Use a phone adapter like this. This adapter need to be pluged into an ethernet port of your router. Believe the 2091 does have 1 port. Only problem with this solution is that you can't use POTS and VOIP on the same handset
2. Purchase a router/modem that support voip like the X5v from Zoom These devices support both POTS and VOIP using the same handset and if there is a powercut the POTS will still work.
Re: BT v2091 router
13-10-2007 12:39 AM
Quote from: itsme If you want to use your DECT phones you have 2 options.
Only problem with this solution is that you can't use POTS and VOIP on the same handset.
Yes you can get a BT phone with 2 lines model BT converse 2025
I have 1 line pots and line2 plustalk voip.
If you have a free port on your router plug a Linksys pap2-na in to it. £13 on ebay and get 2 voip lines you just plug a normal phone in to it
If not plusnet sell a speedtouch 716wl router it has 4 ports 1 usb 1 pots and 1 voip line for less than £70 plus its wireless
And as for getting a dect phone to work on voip is not easy the adapter or voip might not have enough power to work I tried with an old BT dect cordless and failed
Puddy
with a sip voip phone you can make and receive calls with the computer off
Re: BT v2091 router
13-10-2007 2:08 PM
Quote from: puddy
Did you follow the link that was associated with the comment? If so you would have found that it was for a linksys pap2 and these adapters do not support POTS.
Quote And as for getting a dect phone to work on voip is not easy the adapter or voip might not have enough power to work I tried with an old BT dect cordless and failed
Are you saying that you plugged a dect phone is the pap2 adapter and this did not work? Be surpised if this is the case.
Re: BT v2091 router
13-10-2007 2:16 PM
Re: BT v2091 router
16-10-2007 10:08 AM
Quote from: itsme Did you follow the link that was associated with the comment? If so you would have found that it was for a linksys pap2 and these adapters do not support POTS.
What i said is that you can connect 1 line from the PAP2 and a BT line to line 2 with a BT converse 2025 telephone i.e its a 2 incoming line phone.
Quote Are you saying that you plugged a dect phone is the pap2 adapter and this did not work? Be surpised if this is the case.
No I plugged a dect phone in to my speedtouch 716wl router which has 2 built in voip ports and it did not work. The problem was that you cannot increase the power supply to power it properly. You can change the power setting on the Pap2 so it may work!!!
Puddy
