BT fon
BT fon
Is there anything similar to BT fon on Plusnet or can we join it (being part of BT)?
4 REPLIES 4
Re: BT fon
You have to sign up to Fon you will then be able to use BTfon and Fon hotspots in the UK and Fon hotspots worldwide.
Re: BT fon
Would I need a Fon router or can I still use my present router?
Re: BT fon
If you went to roam on to Fon or BTfon hotspot for free than you need a Fon router. With these router you get 2 ssid's. One is secure and the other is open to allow other Fon users to access your broadband. Fon control the router as do BT with the homehubs. If you are prepared to pay for the hotspots then you only need to register
Re: BT fon
Many thanks itsme
I'll have to look deeper to see if its worth me doing.
