BT Voyager 2110 aerial
- BT Voyager 2110 aerial
15-04-2008 10:28 AM
Hi
The aerial is comming apart on the back of my BT Voyager 2110 wireless router and Plusnet say send the whole router back in order to get a replacement...
Anyone know where I can buy a replacement aerial so that I don't have any internet downtime ?
2 REPLIES 2
Re: BT Voyager 2110 aerial
15-04-2008 1:10 PM
If you don't want internet downtime I suggest you buy a second router. That way you will have a known good spare in case of failure. It is also useful to rule out a router issue when you have connection problems.
15-04-2008 11:13 PM
Most aerial are a standard fit so you may pick one up off a car boot the other option is that some wireless network cards use the same aerial so it may be cheaper to get one of them just for aerial
