BT Sport - Activation query
andydp
Hi all,
I added BT Sports (HD) to my Sky subscription via the Plusnet website earlier today, however upon completing was told I would need a new viewing card. This was a surprise as I had previously entered in my viewing card number when placing the order. Has this happened to anyone else? I called PN about it at lunch, and they said that they could see on my order the viewing card number that I had entered and my order should be complete within 48 hours. This is great, I'm just a bit puzzled as to why I was initially told I'd need a new viewing card?
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: BT Sport - Activation query
Do you have an active Sky subscription?
Basically, the Sky Viewing Card number needs to match up with the Serial Number of your Sky Box as they are registered together. If they don't (Such as purchased separately) we would send a new card out which we would register to the serial number of your Sky Box.
Chris Pettitt
Cloud Environments Engineer
andydp
Thanks for the reply...
Yes, I have an active Sky subscription - the HD box and card were provided by Sky a good couple of years ago. As a result, should I just presume that BT Sport will activate within 48 hours?
Plusnet Staff
Plusnet Staff
Fixes: 5
That's right. If you're already using the Sky Card and it's active, we'll just get the service activated - there will be no need for a new Sky Viewing Card.
Apologies for the confusion!
Chris Pettitt
andydp
Brilliant, cheers Chris - thank you for confirming!
andydp
Quote from: Chris
Chris,
I'm still to hear from PN in regards to activation of the BT HD Sport package - I appreciate it hasn't been 48 hours yet, but looking at other posts regarding activation turnaround seems to be pretty quick?
Thanks.
Plusnet Staff
Plusnet Staff
Fixes: 5
I've just given one of my colleagues a nudge to get that sorted out for you. Apologies for the delay.
Chris Pettitt
Plusnet Staff
Plusnet Staff
Fixes: 5
That should be sorted out for you.
I would expect the channels to start working within the next couple of hours.
Chris Pettitt
Sian2909
I have the same issue. Input Sky Viewing Card no then told a new card will be sent out? Signed up to watch the football tomorrow but doesn't look like it's going to happen now?
