BT Speedtest on Apple etc.
- BT Speedtest on Apple etc.
- « Previous
- 1
- 2
- Next »
Re: BT Speedtest on Apple etc.
14-10-2014 8:59 PM
Chrome has flash integrated into it...
14-10-2014 9:11 PM
Quote from: TORPC The one I was referring to is the one linked from 11110_110 (which is "the new beta version of the thinkbroadband speed test." http://labs.thinkbroadband.com/ispa/
yup, works fine in Chrome.
Quote from: 11110_110 You can make is as big as you like... your obviously running flash plugin or other, this is a stock mac with firefox installed period, IE which as others have pointed out doesn't WORK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
CHROME, no flash plugin as DaveyH points out flash is integrated.
14-10-2014 9:13 PM
@dvorak
Does any of the BT Speedtesters as OJ was referring to (work on your MAC) ?
14-10-2014 9:15 PM
yup, all work fine.
14-10-2014 9:17 PM
HTML5, why would i want flash, might as well have windows.
14-10-2014 9:20 PM
Quote from: dvorak yup, all work fine.
Which browser(s) / versions & have you got any flash / Java etc plugins installed
Or is it stock like 11110_110's ?
What version MAC are you using ?
@11110_110
For comparison what version MAC & Firefox are you using ?
14-10-2014 9:24 PM
mavericks and chrome.
14-10-2014 9:44 PM
This thread is getting rather confusing or maybe people are confusing themselves.
The majority of speed tests will work on a Mac OSX machine, with the flash plugin installed (including the ones already mentioned - BT TBB).
With regards to the TBB warning notice, most will not see an issue with it regardless of what browser is used, the problem occurs on faster lines i.e. fibre (much like the mybroadband speed test - remember that one?).
The only useful thing with the BT speed test is getting the further diagnostics to find the IP profile on your line.
That's RPM to you!!
14-10-2014 9:49 PM
Cheers for the clarification RPM
- « Previous
- 1
- 2
- Next »
