BT Speedtest on Apple etc.
- BT Speedtest on Apple etc.
14-10-2014 10:34 AM
I watched the video and it states that you can't run the speed test as Apple and Android don't support Flash
Quote from: _Adam_Walker_ We're also producing support videos now, here's one about broadband speed checks: https://www.youtube.com/watch?v=tKnZUl3kc3Y&list=PLZx9FPn3_-IWW7WetOtIy8JV4reZCA0MU
Can I have some comments/suggestions for the misguided souls who don't have a proper computer
Re: BT Speedtest on Apple etc.
14-10-2014 11:56 AM
Tested http://speedtest.btwholesale.com/ & see
http://diagnostics.bt.com/login/?workflow=Speed redirects to http://www.BT.com/help & says
with no options to carry out a speedtest
Quote You will need to be connected to your laptop or desktop computer in order to perform an accurate seed test.
A quick look in the App store does not show ant BTSpeedtest see https://play.google.com/store/search?q=BT%20speedtest&c=apps&hl=en
It seems that they have Apss for Wifi / Sport SmartTalk / Cloud / Mobile Express, yet not a single one for Speed, see https://play.google.com/store/search?q=BT&c=apps&hl=en
14-10-2014 12:22 PM
Quote from: Oldjim I watched the video and it states that you can't run the speed test as Apple and Android don't support Flash
Can I have some comments/suggestions for the misguided souls who don't have a proper computer![]()
they need to be more specific iOS doesn't support flash, Mac OS X does and you can run all the speedtests with no issues.
having not watched the video, not sure if that's clear or not. trusing your old ears here Jim
14-10-2014 3:07 PM
either the video is wrong or your ears are mishearing.
flash of course works on "apple", and by apple i assume they mean any system running Mac OS X.
of course, iOS doesn't support Flash, but you wouldn't be running a BTW speedtest on a wireless mobile device anyway surely.
android, depends which version of android, early versions do, current versions don't.
but again, why would anyone run a BTW speedtest on a wireless mobile device?
14-10-2014 3:41 PM
14-10-2014 3:48 PM
14-10-2014 3:54 PM
14-10-2014 7:57 PM
14-10-2014 8:10 PM
However will it run the BT Speedtester(s) as linked above ?
14-10-2014 8:22 PM
14-10-2014 8:26 PM
Quote from: TORPC That's conclusive that MAC will run a speedtest albeit in Beta
eh? i use the tbb one in chrome and it's fine, speedtest works in safari.
i'd stick to windows if I were you.
14-10-2014 8:29 PM
pic2 Safari
Not on mine it don't ?
Edit: pics corrected...
14-10-2014 8:41 PM
14-10-2014 8:45 PM
14-10-2014 8:46 PM
Quote from: dvorak
The one I was referring to is the one linked from 11110_110 (which is "the new beta version of the thinkbroadband speed test." http://labs.thinkbroadband.com/ispa/
Which 11110_110's Screenshot in the post immediately above mine, clearly shows it working on his MAC
