BT Speedtest on Apple etc.
Oldjim
Resting Legend
Fixes: 63
Quote from: _Adam_Walker_
We're also producing support videos now, here's one about broadband speed checks: https://www.youtube.com/watch?v=tKnZUl3kc3Y&list=PLZx9FPn3_-IWW7WetOtIy8JV4reZCA0MU
I watched the video and it states that you can't run the speed test as Apple and Android don't support Flash
Can I have some comments/suggestions for the misguided souls who don't have a proper computer  Grin Roll_eyes
23 REPLIES 23
TORPC
Re: BT Speedtest on Apple etc.
I use the Speedtest.net App on all Droid devices, however I will test since I am also curious Wink
Tested  http://speedtest.btwholesale.com/ & see & it won't let me choose yes or no
http://diagnostics.bt.com/login/?workflow=Speed redirects to http://www.BT.com/help & says
You will need to be connected to your laptop or desktop computer in order to perform an accurate seed test.
with no options to carry out a speedtest
A quick look in the App store does not show ant BTSpeedtest see https://play.google.com/store/search?q=BT%20speedtest&c=apps&hl=en
It seems that they have Apss for Wifi / Sport SmartTalk / Cloud / Mobile Express, yet not a single one for Speed, see https://play.google.com/store/search?q=BT&c=apps&hl=en
Fixes: 1,483
Quote from: Oldjim
they need to be more specific iOS doesn't support flash, Mac OS X does and you can run all the speedtests with no issues.
having not watched the video, not sure if that's clear or not. trusing your old ears here Jim Wink
chenks76
All Star
Fixes: 12
Quote from: Oldjim
either the video is wrong or your ears are mishearing.
flash of course works on "apple", and by apple i assume they mean any system running Mac OS X.
of course, iOS doesn't support Flash, but you wouldn't be running a BTW speedtest on a wireless mobile device anyway surely.
android, depends which version of android, early versions do, current versions don't.
but again, why would anyone run a BTW speedtest on a wireless mobile device?
Oldjim
Resting Legend
Fixes: 63
Nothing wrong with my hearing 1 min 18 secs in
chenks76
All Star
Fixes: 12
so the video is wrong then.....
Oldjim
Resting Legend
Fixes: 63
Raised here http://community.plus.net/forum/index.php/topic,132889.0.html along with a few other things
30FTTC06
Fixes: 4
TORPC
That's conclusive that MAC will run a speedtest albeit in Beta
However will it run the BT Speedtester(s) as linked above ?Huh
30FTTC06
Fixes: 4
NO, nor does the thinkbroadband test work either...
Fixes: 1,483
Quote from: TORPC
eh? i use the tbb one in chrome and it's fine, speedtest works in safari.
i'd stick to windows if I were you.
30FTTC06
Fixes: 4
Pic 1 Firefox
pic2 Safari
Not on mine it don't ?
Edit: pics corrected...
Fixes: 1,483
no such message here
30FTTC06
Fixes: 4
You can make is as big as you like... your obviously running flash plugin or other, this is a stock mac with firefox installed period, IE which as others have pointed out doesn't WORK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
TORPC
Quote from: dvorak
Quote from: TORPC
The one I was referring to is the one linked from 11110_110 (which is "the new beta version of the thinkbroadband speed test." http://labs.thinkbroadband.com/ispa/
Which 11110_110's Screenshot in the post immediately above mine, clearly shows it working on his MAC
