BT SPORT Activation Success
- Re: BT SPORT Activation Success
26-08-2014 6:39 PM
Requested online at 8:45 this morning. Confirmation email and text received at 15:11. Couldn't check before 18:00, but all HD channels present. Happy. Bit annoying that the confirmation screen said I needed a new card, which clearly I didn't.
1 REPLY 1
27-08-2014 11:41 AM
Morning whitecottage,
Thanks for the feedback.
There's two different 'initial notices' we use when a BT sport order is placed. The one you received is sent when you tick the box 'require a new card' on sign up but as you have already given us the viewing card number we don't need to send you a new card.
I hope that explains things
