BT Router
- BT Router
BT Router
27-08-2018 6:53 PM
Hopefully this is a really simple question.
If I buy the BT home hub 6 - Will I be able to use it and keep my plusnet account the same or do I have to use the plusnet router.
I think I know the answer but don't want to fork out on a new router only to find I can't use it.
Re: BT Router
27-08-2018 7:04 PM
After my recent last swap from BT back to Plusnet, yup, I'm a serial switcher! I just continued to use my BT HH6 with absolutely no issues.
Re: BT Router
27-08-2018 7:10 PM - edited 27-08-2018 7:11 PM
Thanks for that,
Think I will just take the plunge and buy one. Thanks again for your response
(I blame you if it doesn't work )
Re: BT Router
27-08-2018 7:27 PM
Re: BT Router
27-08-2018 7:53 PM
Thanks for that link,
Do you know it just stupidly dawned on me that to connect a router I would need a router to get on the net to get instructions on how to connect my router!!!
Might just copy that page now
Thanks again
Re: BT Router
27-08-2018 7:58 PM
Just for info when setting up a BT Smart Hub (6)
The router will not accept any passwords that have . +*?/ or similar
