BT Home Hub
pies
BT Home Hub
Mother is about to end het BT contract soon and will be moving to plusnet,assuming she is in a low cost area,will het home hub work on Plusnet without any mods.
TIA Smiley
scootie
Re: BT Home Hub
thing it depends on what version of home hub it is
Fixes: 247
Re: BT Home Hub
You should be able to grab the free router from PN, if you want to replace the homehub.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
