BT Home Hub
- BT Home Hub
BT Home Hub
11-04-2009 8:30 PM
Mother is about to end het BT contract soon and will be moving to plusnet,assuming she is in a low cost area,will het home hub work on Plusnet without any mods.
TIA
TIA
2 REPLIES 2
Re: BT Home Hub
11-04-2009 8:32 PM
thing it depends on what version of home hub it is
Re: BT Home Hub
11-04-2009 10:30 PM
You should be able to grab the free router from PN, if you want to replace the homehub.
