BT Fibre exchanges
artmo
Aspiring Champion
BT Fibre exchanges
BT has announced the first 29 exchanges for fibre deployment:
http://tinyurl.com/c3km3a
15 REPLIES 15
James
Re: BT Fibre exchanges
*sigh*
Hemel Hempstead is my parents old exchange before they moved.
Lurker
Yays - My exchange is on the list...
James
Isn't yours a tiny one?
Lurker
29,804 residential premises
1,397 non-residential premises.
http://www.samknows.com/broadband/exchange/MYPUD
scootie
dose'nt  james_G all ready live close to exchange and gets a nice sync on adsl.
come on BTw give us 50+db atten lines a break Angry
whats PN going to do with customers that are able to go on the fibre trial?
Fixes: 1,483
be careful what you wish for.. they break your line you'll have nothing  Wink  Cheesy
scootie
they broke it many times before and all they do is get a mr men plaster and stick it back togther. cheap skates
Lurker
Quote from: ASBO
Nah, I live miles away from the exchange - on the 21CN trial I only manage around 3Mbps.
You might be confusing an earlier comment about a 27dB Attenuation, but unfortunately this applies on my work connections only.
No such luck for at home!
scootie
yep 27ish was the fig i had in mind
hulls
Chelmsford number one on the list!  Roll_eyes
But what will it mean for my service?
John  Huh
Lurker
Nothing at all - at least not for a long while!
The list of exchanges has been released, but they haven't actually started the work yet, and when they do, it'll take quite a while.
And then you need to find an ISP that has products that can take advantage of the new network.
So basically, pretend nothing is happening for a while, and wait to see what comes of it!
pierre_pierre
they have left two of the list Ebsfleet Kent (Large) and Kersey Suffolk (A small village) both I think done
Lurker
Pierre - I doubt it somehow; everybody talks about it being a 'list of 29' exchanges, so if two have been missed off the list, that means it would be a list of 31.
Or, two of the ones on there are not being done at all.
Either way, I don't think its likely that Kent and Suffolk would have been done already, when BT have said that the first two the will do are in London and Wales.
Think you might have been mislead by somebody. Wink
MauriceC
Resting Legend
Fixes: 17
Ebbsfleet was the trial location for BT deployment of Fibre rather than copper  see here  Though there is some confusion in a number of the reports as to whether they are trialling FTTC or FTTP?
My interpolation is that it is most likely to be FTTC Smiley
See here for some later details
as I see it the "list of 29" is for the first 'live' deployment as opposed to the pilot at Ebbsfleet.    Good reports out of Ebbsfleet on the methods (and costs!) of actually achieving the deployment.
Sadly my exchange is unlikely to even get 21CN until whenever  Cry
