BT Fibre exchanges
- Re: BT Fibre exchanges
BT Fibre exchanges
30-03-2009 10:09 AM
30-03-2009 10:13 AM
Hemel Hempstead is my parents old exchange before they moved.
30-03-2009 10:48 AM
30-03-2009 10:51 AM
30-03-2009 10:53 AM
1,397 non-residential premises.
http://www.samknows.com/broadband/exchange/MYPUD
30-03-2009 4:12 PM
come on BTw give us 50+db atten lines a break
whats PN going to do with customers that are able to go on the fibre trial?
30-03-2009 4:14 PM
30-03-2009 4:18 PM
30-03-2009 4:49 PM
Quote from: ASBO dose'nt james_G all ready live close to exchange and gets a nice sync on adsl.
Nah, I live miles away from the exchange - on the 21CN trial I only manage around 3Mbps.
You might be confusing an earlier comment about a 27dB Attenuation, but unfortunately this applies on my work connections only.
No such luck for at home!
30-03-2009 4:50 PM
30-03-2009 5:04 PM
But what will it mean for my service?
30-03-2009 5:53 PM
The list of exchanges has been released, but they haven't actually started the work yet, and when they do, it'll take quite a while.
And then you need to find an ISP that has products that can take advantage of the new network.
So basically, pretend nothing is happening for a while, and wait to see what comes of it!
30-03-2009 6:31 PM
31-03-2009 11:15 AM
Or, two of the ones on there are not being done at all.
Either way, I don't think its likely that Kent and Suffolk would have been done already, when BT have said that the first two the will do are in London and Wales.
Think you might have been mislead by somebody.
31-03-2009 11:45 AM
My interpolation is that it is most likely to be FTTC
See here for some later details
as I see it the "list of 29" is for the first 'live' deployment as opposed to the pilot at Ebbsfleet. Good reports out of Ebbsfleet on the methods (and costs!) of actually achieving the deployment.
Sadly my exchange is unlikely to even get 21CN until whenever
