BIOS setup not there anymore
- BIOS setup not there anymore
23-08-2013 2:58 PM
I have just installed a Linux distro bit I need to install a newer version of it. However the PC keeps booting strait on to linux, ie, by pressing f2 or del it will not let me access the setup. My MB is an Asrock. Any ideas?
6 REPLIES 6
Re: BIOS setup not there anymore
23-08-2013 3:16 PM
Strange, do you have it set to suspend or hibernate?
You could edit your /boot/grub/grub.cfg and change the timeout.
23-08-2013 3:22 PM
How does one do that? It is the PCLinus KDE distro that I have.
23-08-2013 3:27 PM
open a terminal
get root
<text editor> /boot/grub/grub.cfg
e.g. for me
sudo pluma /boot/grub/grub.cfg
or install super-boot-manager and choose the grub setup.
I think if you press a key at startup then grub will display a menu, but been a long time since I used grub.
get root
e.g. for me
23-08-2013 4:26 PM
Quote from: morgan2476 My MB is an Asrock.
Don't have happy memories of asrock MBs, but it may have been a bad batch (of 60!).
Have you tried repeatedly tapping del/f2 (or is it ESC?) from power-on - I have had to do that on a number of occasions as the "window" time depended on the processor speed
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
23-08-2013 6:25 PM
If you're choosing reboot, try shutting down and powering off instead.
24-08-2013 2:42 AM
Problem Solved. I reset the bios.
