BBC iPlayer
Minivanman
Legend
BBC iPlayer
For some reason BBC iPlayer has stopped working on my laptop.
I can get as far as finding a programme but when pressing play nothing happens and yes, I am registered and I have signed in.
Works fine on my television and on my kindle so now I'm wondering if there is some sort of conflict somewhere - although it's been fine up until now. There is no deinstall/reinstall facility that I can see as that usually sorts things out.
Any ideas guys? (Scratches head)
Truth is like a threshing machine; tender sensibilities must keep out of the way.
Herman Melville
10 REPLIES 10
Mav
Fixes: 515
Re: BBC iPlayer
Do you have the correct version installed?
Bear in mind the latest version currently does not allow you to change where downloads are stored.
Forum Moderator and Customer
Minivanman
Legend
Re: BBC iPlayer
Checked and installed latest version but still playing silly bees so will give it a rest for a while as it's now driving me Crazy2
Cheers.
Herman Melville
jelv
Fixes: 10
Re: BBC iPlayer
There is no install for the watching on-line version, only for the download and watch later.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Minivanman
Legend
Re: BBC iPlayer
Really?
Thanks will check that out and why perhaps I cannot find it in a downloaded file in order to uninstall and reinstall.
Cheers.
Herman Melville
VileReynard
Fixes: 20
Re: BBC iPlayer
Try get_iplayer for downloads - this works for me.
Apparently there is also a Windows version.
You also get a (kind of) PVR with it.
RobPN
Fixes: 13
Re: BBC iPlayer
Try a different browser?
DaveyH
Champion
Fixes: 12
Re: BBC iPlayer
Yep. Been using it for years.
It's cross platform, with versions for Linux, Windows and Mac
https://www.squarepenguin.co.uk
https://github.com/get-iplayer/get_iplayer
There's also a  fork called Get iPlayer Automator that has a GUI for Mac users who aren't comfortable with CLI
https://github.com/Ascoware/get-iplayer-automator
VileReynard
Fixes: 20
Re: BBC iPlayer
Linux also optionally provides a GUI Grin which is just a web page generated locally that you can look at in a web browser.
DaveyH
Champion
Fixes: 12
Re: BBC iPlayer
Yeah for the 'web pvr',  so not really the same as the GUI provided by GIA
ReedRichards
Seasoned Pro
Fixes: 25
Re: BBC iPlayer
iPlayer (streaming) used to use Flash Player but now, by and large, doesn't.  Does visiting this page http://www.bbc.co.uk/html5 provide any clues?
