BBC iPlayer
- Re: BBC iPlayer
BBC iPlayer
04-03-2018 11:05 AM
For some reason BBC iPlayer has stopped working on my laptop.
I can get as far as finding a programme but when pressing play nothing happens and yes, I am registered and I have signed in.
Works fine on my television and on my kindle so now I'm wondering if there is some sort of conflict somewhere - although it's been fine up until now. There is no deinstall/reinstall facility that I can see as that usually sorts things out.
Any ideas guys? (Scratches head)
Truth is like a threshing machine; tender sensibilities must keep out of the way.
Herman Melville
Re: BBC iPlayer
04-03-2018 11:11 AM - edited 04-03-2018 11:11 AM
Do you have the correct version installed?
Bear in mind the latest version currently does not allow you to change where downloads are stored.
Forum Moderator and Customer
Re: BBC iPlayer
04-03-2018 11:47 AM
Checked and installed latest version but still playing silly bees so will give it a rest for a while as it's now driving me
Cheers.
Herman Melville
Re: BBC iPlayer
04-03-2018 11:55 AM
There is no install for the watching on-line version, only for the download and watch later.
Re: BBC iPlayer
04-03-2018 12:09 PM
Really?
Thanks will check that out and why perhaps I cannot find it in a downloaded file in order to uninstall and reinstall.
Cheers.
Herman Melville
Re: BBC iPlayer
04-03-2018 1:19 PM
Try get_iplayer for downloads - this works for me.
Apparently there is also a Windows version.
You also get a (kind of) PVR with it.
Re: BBC iPlayer
04-03-2018 1:58 PM
Try a different browser?
Re: BBC iPlayer
04-03-2018 5:00 PM - edited 04-03-2018 5:02 PM
Yep. Been using it for years.
It's cross platform, with versions for Linux, Windows and Mac
https://www.squarepenguin.co.uk
https://github.com/get-iplayer/get_iplayer
There's also a fork called Get iPlayer Automator that has a GUI for Mac users who aren't comfortable with CLI
https://github.com/Ascoware/get-iplayer-automator
Re: BBC iPlayer
04-03-2018 7:53 PM
Linux also optionally provides a GUI which is just a web page generated locally that you can look at in a web browser.
Re: BBC iPlayer
04-03-2018 8:11 PM
Yeah for the 'web pvr', so not really the same as the GUI provided by GIA
Re: BBC iPlayer
05-03-2018 8:16 AM
iPlayer (streaming) used to use Flash Player but now, by and large, doesn't. Does visiting this page http://www.bbc.co.uk/html5 provide any clues?
