BBC iPlayer tries to load AIR
- BBC iPlayer tries to load AIR
04-07-2010 5:06 PM
When I go to some programmes on iPlayer, select one so I can click on the picture to play it as flash,
It attempts (but luckily fails) to load AIR Malware.
It gives me the same error message 3 times.
This appears to be since I installed the Adobe fix for all the security holes in Acrobat.
All this happens in 64 bit W7
(Oh - just realised - Adobe don't do 64bits, do they?)
Luckily get_iplayer is working again.
6 REPLIES 6
Re: BBC iPlayer tries to load AIR
04-07-2010 8:23 PM
BBC iPlayer needs Adobe Air.
04-07-2010 10:01 PM
I run BBC iPlayer on Lucid Lynx (32 bit) and that installed AIR during the original setup, and has since insisted in having an AIR update before iPlayer would continue.
04-07-2010 10:06 PM
Quote from: ReedRichards BBC iPlayer needs Adobe Air.
Only for downloading, not for using the Flash player on the iPlayer website (which is what A Fox is Evil was trying to do).
04-07-2010 11:42 PM
Indeed - I'd never load AIR - but the BBC website on Windows 7 seemed to be trying to.
If I want to download from the iPlayer I use the get_iplayer program.
Seems that Adobe have forgotten how to write decent software.
05-07-2010 9:18 AM
Did they ever know
05-07-2010 4:10 PM
Not for the first time, I updated 2 of my systems with an Adobe Reader automatic update this weekend; neither system would hibernate until I used the disk clean-up and PC tools registry cleaner utilities to clear up the mess left behind. If I didn't need the Adobe products, I'd ditch them.
