BBC iPlayer + limiting usage?
Gilbie
Hi all
Does anyone have any suggestions on how I can limit usage of iPlayer? We have 15GB per month which gets eaten up fairly quickly by the kids watching Eastenders Cbeebbies.  There is a low bandwidth options but educating a 5yr old to select this is proving tricky.
Any tips would be appreciated.
pierre_pierre
Re: BBC iPlayer + limiting usage?
a five year old should not be using the internet without parents being there
Fixes: 131
I welcome you to the forums Gilbie but I have to agree with Pierré.
If you have unrestricted access to the internet then youngsters need supervision.
Vista offers limited control of usage to a selected user profile with it's Parental Controls.
Customer and Forum Moderator.
pierre_pierre
you could also take them out for a ride
One completely daft suggestion would be to try to get a worse broadband connection!  If you have a low speed (<<3500kbps) then HQ will not play smoothly (iPlayer should automatically switch to LQ if the connection is low speed).
Maybe PN could cap your line (if you want this!)? Crazy
Call me 'w23'
Gilbie
Many thanks for your quick replies - understand about supervising children on the internet. We are very carefull about this and as its a desktop computer in the main living area we are always around when its in use. The platform is XP home so unable to use the Vista controls. I should add that its not just a 5yr old that uses iPlayer but a 7 and 11 yr old. Good point about lowering the bandwidth, is there a free / cheap app that I could use to throttle the NIC?
Steve
Seasoned Pro
Why dont they just watch the tv rather than eating up all the bandwidth,you could always move to tiscali(talk talk)i know there service is lousy
If life gives you lemons, make lemonade.
Gilbie
Quote from: steve74
Genius..............  Crazy
Fixes: 54
You might want to take a look at K9 Web Protection here http://www1.k9webprotection.com/index.php
Whilst it cant throttle the NIC it would allow you to block access to iplayer live.
You could for instance block www.bbc.co.uk/iplayer/playlive/ either totally or for certain times of the day.
Hope that helps
