BBC i Player
southken
BBC i Player
Does anyone know if it is possible to record from the iplayer and if so how would you go about it.  Thanks
Infinity
Seasoned Pro
Re: BBC i Player
Using Apple iMac, OSX & QT 10.2, I record the screen movie, full screen.
Audio via o/p to i/p via splitter
I'm sure similar apps are available for PC's.
Most BBC iPlayer programmes are available on iplayer (Mac only) which have no time limit imposed.
Fixes: 20
Re: BBC i Player
southken
Re: BBC i Player
Thanks for your suggestions, I have also found a bbc iplayer desktop application to download from the bbc, I haven't tried it yet but that could work aswell.
southken
Re: BBC i Player
I would just like to add an update to my original query regarding the iplayer.  The is an iplayer desktop app which you can download from the bbc website, then you can record programmes and keep them for 30 days, once you've watched them you can remove them.  There is a 4gb limit to the amount of downloads.  I think it's a very useful tool, it means you can download during your free allowance time and watch when you want.
Infinity
Seasoned Pro
Re: BBC i Player
There is no 4gb Limit, you can set your own limit in preferences.
Mine is set at 20gb.
southken
Re: BBC i Player
Thanks for that, I didn't realise you could change it!
