BBC i Player downloads
davidj66
Just trying to find out if there is a way of time scheduling SINGLE downloads of BBC progs.?? I know you can set up a schedule for series recordings., but occasionally I might have missed one episode or programme and want to schedule d/l overnight.
Fixes: 247
Re: BBC i Player downloads
you could try using get_iPlayer, there is a windows exe here http://www.infradead.org/get_iplayer/html/get_iplayer.html
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Infinity
Seasoned Pro
Quote from: davidj60
Fixes: 247
And you've just proven his point?
Infinity
Seasoned Pro
It also works for single downloads !!
Despite the heading
Infinity
Seasoned Pro
Another dupe by very slow loading !
You may delete this one.
davidj66
So even if its a one off the schedule will work? Thanks very much PlusComUK!! Smiley
edit - Oh no it doesn't! Even when a scheduled d/l time is set for "series record" directly you click the D/L link it starts! You can pause it - but then you need to be there to restart it in the free o/night period.
