BBC Iplayer can I schedule a download?
- BBC Iplayer can I schedule a download?
31-03-2009 8:55 PM
Hi All
I'm tending to use BBC Iplayer to view TV programs, its easy to set up, use and download.
BUT I like to make use of the plusnet 'free download time' and download the program overnight (I can only get 512kb download speed so a 1 hour program can take 5-6 hours).
DAK if its possible to 'schedule' a download time to 'start' the Iplayer download say at 01:00am.
TIA
D
TIA
D
3 REPLIES 3
Re: BBC Iplayer can I schedule a download?
31-03-2009 10:19 PM
It can be done:
http://odmonitor.blogspot.com/
01-04-2009 1:02 AM
i run the that od monitor. very useful to make sure your kservice is stoped from uploading at will. not used the schelduer before but just taken a capture of the menu.
Its designed for use with all the major uk OD providers and runing on vista has bein problem free for me
01-04-2009 9:42 AM
Another one to look at is get_iplayer http://linuxcentre.net/
It works on windows/Linux/mac I use it all the time to get the radio programs, but it also does tv proggies.
