BB Phone daft messages
glloyd
If the number you are calling is engaged you get a message " Unable to connect you at the moment, please check for any current issues.........". Why not simple give the engaged tone like other providers instead of having to log on to see if there is a fault?
astarsolutions
Re: BB Phone daft messages
Because the Asterisk platform they use doesn't know the difference between an engaged line and a network failure.
glloyd
Must be a pretty poor platform then. other providers manage it. Maybe that's why it keeps falling over.
astarsolutions
Asterisk is an amazing platform; the inability to detect the line status is the only annoyance I have ever come across.
Asterisk itself is very stable so I have no idea why Plustalk has so many problems.
fotobits
Are you suggesting that PlusTalk is working?
Except for a really good period about a month ago, I've found PlusTalk back to the unreliable days of last year!
Yet the Status remains green!
astarsolutions
I have Plustalk setup as a backup link so if my main VoIP service goes down it fails over to Plustalk. Thankfully I haven't had to experience the joys of Plustalk yet.
pcoventry76
Quote from: fotobits
Yes it's working i just used it for 1 hour 35 minutes without a problem
glloyd
Your lucky then. Nine out of ten times it comes up with a server not responding error but if you try enough times it may connect you.
