Avast 5 Progress Bar Bug.(Now Fixed)
Steve
Seasoned Pro
Just a heads up, Im using windows 7 home premium and running the avast pro 5.0.462 build, When i do a full system scan the progress bar jumps to 100% pretty much as soon as you start scanning,Seems theres another prog update about to come out but not sure what its fixing.
Anyway heres a link to the known prob with the progress bar...http://forum.avast.com/index.php?topic=57986.0
Edit, This bug is fixed now with Update;V.B. Current version:100406-1
If life gives you lemons, make lemonade.
