Autofill login details on mobile phone
NickyOver
On my laptop and tablet, when I log into Plusnet webmail, my login details appear automatically, but when I do so on my mobile phone (I am not on Plusnet for my mobile), I have to fill them in each time. How can I get the details to appear on my phone like they do on the other devices?
5 REPLIES 5
Fixes: 1,483
Re: Autofill login details on mobile phone
Moderators Note
This topic has been moved from Mobile to Tech Help.
Fixes: 1,483
That's a feature of the browser on your phone, if you mention which browser and phone os you have someone maybe able to point you in the right direction.
NickyOver
Thanks. I have a Samsung Galaxy A41 running on the Android system and use the Chrome browser. My tablet is also Samsung, and I use Chrome, and it autofills without a problem.
Fixes: 1,483
Have you got sync turned on in chrome?
That should sync all your remembered passwords etc.
NickyOver
I have turned sync on on my phone, but it was not turned on on my tablet. Now it is and the details are saved!
