Auto Setup TR069
30FTTC06
Fixes: 4
Auto Setup TR069
Anybody explain why Auto setup has automagically turned itself back on?
I turned this OFF when we first joined plusnet expecting that it would stay off, however, today while mooching It is now turned on.
5 REPLIES 5
Oldjim
Fixes: 63
Re: Auto Setup TR069
at a guess - if you get a new router it would happen
w23
Fixes: 4
Product change often 'resets' defaults too.
Call me 'w23'
MatthewWheeler
Fixes: 464
From what I can see it's down to the new router that was ordered a couple of months ago.
 Matthew Wheeler
30FTTC06
Fixes: 4
Ok thanks all, that would explain it, I was under the impression off was off so I'll bear it mind for future changes of product.
nanotm
iirc bt branded homeplugs can cause the problem as well (as can some others) when they "search and update" similar functions can also be performed by smart TV's /set top boxes and mobile devices, it was something to do with some report home feature that would routinely check for TR069 settings and then send a change request using the admin info saved from the last time you logged into the router via the device.
had a similar problem with certain devices in the past (a few years ago) changing the setting within minutes of me switching it off, wire shark found the culprit and I was able to sort it out (by changing the router's admin password) so it didn't get switched n again unless I actually wanted to use it /
