Auto Setup TR069
- Re: Auto Setup TR069
Auto Setup TR069
11-06-2015 10:48 AM
Anybody explain why Auto setup has automagically turned itself back on?
I turned this OFF when we first joined plusnet expecting that it would stay off, however, today while mooching It is now turned on.
5 REPLIES 5
11-06-2015 1:14 PM
at a guess - if you get a new router it would happen
11-06-2015 1:20 PM
Product change often 'resets' defaults too.
Call me 'w23'
11-06-2015 3:12 PM
11-06-2015 3:29 PM
Ok thanks all, that would explain it, I was under the impression off was off so I'll bear it mind for future changes of product.
11-06-2015 6:28 PM
iirc bt branded homeplugs can cause the problem as well (as can some others) when they "search and update" similar functions can also be performed by smart TV's /set top boxes and mobile devices, it was something to do with some report home feature that would routinely check for TR069 settings and then send a change request using the admin info saved from the last time you logged into the router via the device.
had a similar problem with certain devices in the past (a few years ago) changing the setting within minutes of me switching it off, wire shark found the culprit and I was able to sort it out (by changing the router's admin password) so it didn't get switched n again unless I actually wanted to use it /
