Audio delay when streaming
Tara1984
I have been having issues when streaming. When I watch ITVX and Netflix on my laptop there seems to be a voice delay. I thought maybe it is because my internet connection was slow. I have upgraded to full fibre and that was installed yesterday but I’m still getting the voice delay and I don’t know why. I have tried a different browser but it’s just the same.
4 REPLIES 4
Fixes: 479
Re: Audio delay when streaming
Moderator's note:
Thread moved from Broadband to Tech Help
Fixes: 479
@Tara1984
This will be a problem with your PC, not your Internet connection. Does this help: https://www.thewindowsclub.com/how-do-i-fix-audio-and-video-out-of-sync-on-windows
markhawkin
Champion
Fixes: 22
Just a guess, but are you using Bluetooth headphones?
I've had this problem with Bluetooth.
If so and it's possible to change the codec used (this may or may not be possible) something like APT-X might help.
Otherwise try some wired headphones and see if that helps.
Tara1984
Thank you for sending me the link. I have tried to look at the settings and change the settings but it is still the same 😟
