Asus Rampage III Extreme motherboard
Anyone using this board? If so, have you updated to BIOS v1502, and if you have are you seeing multiple POST sequences?
1 REPLY
Re: Asus Rampage III Extreme motherboard
Sorted! Nothing to do with the BIOS, more to do with a random decision on the part of W7 to scramble the power management settings. Why does it do that?Huh
Sad
