Asus Eee & Option 2 free router
Will71
I've a friend who has an Asus Eee and no ISP, does anyone know if the Linux based Asus (no CD/DVD drive) & the free router with option 2 are compatible? If so, is the router standalone, or does it require a desktop to be plugged in to setup?
They mentioned phoning BT, but due to my great experience with Plusnet, I would like to give them another option.
Re: Asus Eee & Option 2 free router
The router is compatible.
However, to configure the wireless security, its generally a requirement to use a cable to the router initially.
Do Eee's have Cat5 network sockets? (I have a suspicion not)
Yes, they do Smiley
B.
In that case, the OP's friend will be able to do the complete setup using the web browser on the Eee.
Will71
Thankyou very much for the info. it is greatly appreciated.  Smiley
