Asus DSL-AC68U
stepea001
Asus DSL-AC68U
I'm having problems getting online with the Asus AC68U modem/router - over the last few months, it just fails to connect with no apparent reason why after weeks of connection - I'm now online after connecting a TP-Link TD-W8960N after spending the last 30 minutes of trying to connect with the Asus, the TP-Link worked straight away.  What I would like to happen is use the TP-Link (because it's more stable) as the modem with the Asus as the router.  I understand I could link the two as a bridge, is there any clear/simple instructions for me to do this.
16 REPLIES 16
NorthPole
Fixes: 6
Re: Asus DSL-AC68U
Just wondered which firmware version you are running on the Asus - some of the earlier ones were known to be somewhat 'flakey'. If you haven't done so already, might be worth upgrading to the latest version before giving up on it as a modem.
stepea001
Re: Asus DSL-AC68U
I upgraded the firmware a few weeks ago, I'm losing patience slightly, this is my second Asus router. Returned the first and got a replacement. What concerns me more, it will go weeks without any problems then it decides it won't connect so I eventually tried the TP-Link and was up and running in a few minutes. The Asus isn't cheap and I'd expect it to be more stable.
rongtw
Fixes: 12
Re: Asus DSL-AC68U
Must admit Not to have any problems with my AC68U Cool
stepea001
Re: Asus DSL-AC68U
Anything different in the settings
rongtw
Fixes: 12
Re: Asus DSL-AC68U
have a look here https://community.plus.net/t5/Fibre-Broadband/Asus-DSL-AC68U/m-p/1300134/highlight/true#M33591
and here https://community.plus.net/aptgm87544/attachments/aptgm87544/Fibre/41551/1/2016-07-14_142037.png
stepea001
Re: Asus DSL-AC68U
So if I'm connected direct to the phone docket (not fibre) do I keep the internet connection settings as ADSL WAN or change to VDSL WAN.
NorthPole
Fixes: 6
Re: Asus DSL-AC68U
No, VDSL WAN is only for fibre (FTTC) connections.
stepea001
Re: Asus DSL-AC68U
That's what I thought, just looking at posts in the other forums for Asus AC68 mention VDSL. I'm back up and running but fed up with the router not connecting after weeks of it being stable. Hoping someone could advise me of the best settings to use.
ejs
Aspiring Hero
Fixes: 25
Re: Asus DSL-AC68U
Could you show us the ADSL stats please?
I recall some Asus models couldn't connect on ADSL2+ with a 3dB target SNRM.
stepea001
Re: Asus DSL-AC68U
not sure if this is the screen with the details.
Strange thing is, it will works for weeks then I have trouble connecting, so what's changing.
ejs
Aspiring Hero
Fixes: 25
Re: Asus DSL-AC68U
The DLM may have automatically lowered the target SNRM - this is a good thing as it would have given you more bandwidth. The DLM may have now increased it so now the Asus can connect.
stepea001
Re: Asus DSL-AC68U
so is there anything I can do in the settings or my provider to prevent this in future.
NorthPole
Fixes: 6
Re: Asus DSL-AC68U
Two things occur to me:
1) it may be worth doing a 'hardware reset' using the small button on the back of the router, especially as you have previously installed some firmware updates. This does entail the tedious process of reentering all the settings again, but it can fix connection issues;
2) turn off all the Digital Line Management (DLM) options on the Administration | DSL Setting page, or set them to their default values, as they can otherwise conflict with BTOR's own DLM and cause instability.
stepea001
Re: Asus DSL-AC68U
Thanks I'll give that a try.
