Asus Chromebook
Smith7
All Star
Asus Chromebook
My friend has purchased a Asus Chromebook and there is a long box with 7 items on it Left click Right click etc
It can be around the screen with the end item but he wants to remove it
Has anyone any ideas we have looked on Google
5 REPLIES 5
Fixes: 389
Re: Asus Chromebook
@Smith7 Can you attach an image of this 'box'? I know very little about Chromebooks, but your question gives very few clues.
Fixes: 1,495
Re: Asus Chromebook
Moderators Note
This topic has been moved from General Chat to Tech Help
IMM
Re: Asus Chromebook
Does this search result offer a clue?
To enable left-click functionality on your Asus Chromebook's touchpad, ensure that the tap-to-click feature is enabled. You can do this by going to Settings > Device > Touchpad and toggling on "Enable tap-to-click."
Maybe this one would be better?
To enable the on-screen left click popup on your Asus Chromebook, go to Settings > Device > Mouse and touchpad, then enable the "Enable on-screen keyboard and mouse" option. This will allow you to use the on-screen keyboard and mouse, including the left click popup.
Smith7
All Star
Re: Asus Chromebook
Thanks but he wants to remove this box or put it out of site
On my Lenovo I don't have this box
TheRoadCrew
Fixes: 13
Re: Asus Chromebook
If it's this box:
it's an accessibility feature.
Settings -> Accessibility -> Enable accessibility features; search for 'automatic clicks' and disable to remove the box:
