Are some file compression programs better than others?
Luzern
All Star
Recently I tied to send a file to another chat room, as it happened a pps one, and the compressed file.(.zip) was a little in excess of the maximum permitted size for uploading.
Do any programs exist, preferably free, which will either generally or by request, compress to a greater extent than what I have, or is there a work around?
Luzern
All Star
Re: Are some file compression programs better than others?
Oops My comprssor is Just ZIp It
pierre_pierre
Hang around Lucerne, Yes Zip programs do vary in their efficiency, also with some you can split a file into two and send as two files then join up on expanding. I would have to dig out and find the best though.
Fixes: 10
Z-zip
High compression and ability to split an archive in to several parts.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Luzern
All Star
All looks a bit tecchie Smiley to this computer donkey. How is an archive split? It's not clear to me Embarrassed
pierre_pierre
Have you loaded 7-Zip?  when you run it if you and hover over the file tab in the top row there is an item spilt file, below that merge files.  that is how you split, send and the receive, merge.  is that OK Smiley
Luzern
All Star
Loaded..yes! I used maximum compression to load to archive, then tried to split abd got operation not supported. Have I got my virtual knickers in a twist. I admit that I'm not the sharpest knife on computer matters.
pierre_pierre
Sorry dont know, I normally use Winzip, I do know that 7-zip is more modern but havnt actually used it, now going away to try.
Fixes: 10
You need 7-Zip to be displaying the contents of the directory containing the archive. Select the archive in that list and then try to split it. You can split previously created zip files (including those created by another program) using that method.
