Apple mac OSX Automatic Broadband Speed Tester at specified intervals ?
Is there such a beast (free), I've Googled and got nowhere.
Rather than keep clicking on Speedtest.net at intervals during the day & night, is there a mac app that will do this for me, say every 4 hours, in the background, purely out of interest ?
I'm not up to writing an applescript to do this.
Something like  http://testmy.net/auto ;   , which give inaccurate results for me, and appears to reset the  connection each time, according to the blurb.
16 REPLIES 16
Oldjim
Resting Legend
Fixes: 63
Re: Apple mac OSX Automatic Broadband Speed Tester at specified intervals ?
I have to ask this - WHY BOTHER  Roll_eyes
I like to monitor my speeds !
Especially now there is no need to monitor my usage......
w23
Fixes: 4
You could try signing up for Samknows: http://www.samknows.com/broadband/signup, it's free if you're accepted and platform independent.
Call me 'w23'
Looks interesting, I'll give it a go.
However, it looks like I cannot connect via wi-fi, which would be a problem for me.
Does the Whitebox provide a wireless network?
No. In the European project, the Whitebox does not provide a wireless network.
The wireless capabilities of the device are used purely to passively monitor nearby wireless networks for traffic, ensuring that no tests are run when the line is active.
Perhaps I can monitor the line with the Whitebox via Ethernet, and still connect via Wi-fi to my PN Router.
Let's see what happens now I've registered.
w23
Fixes: 4
The Whitebox operates as an Ethernet bridge, co-existing with an existing modem/router. All wired devices should connect through the Whitebox. Wireless devices should continue to connect to their existing router:
Hope that helps.
Call me 'w23'
Thanks,  I missed that bit !
dave
Fixes: 4
You may be able to use Automator to do it or use the Firefox plugin Selenium. I've used both in the past to do similar stuff (although found Selenium easier to use, maybe because it just automates clicking/typing in Firefox).
Dave Tomlinson
Plusnet Technology
I've found BBSpeedmapper for Firefox, will give it a try.
https://addons.mozilla.org/en-US/firefox/user/5812121/?src=api
Updated today !
Quote from: w23
Quote from: PlusComUK
I've been accepted, monitoring equipment expected in the next 14 days.
Thanks for the suggestion.
Fixes: 1,482
I've had a SamKnows box for a couple of years now and it's very good for monitoring your line.
My SamKnows Whitebox arrived today.
Very easy to install.
Some display problems on dashboard webpage, any of 4 browsers, possibly because I am using Apple iMac running Mountain Lion OSX 10.8.2
I cannot move widgets, and any I add disappear after log-out, or page reload.
SamKnow query raised.
Anyway, here are my first results, after a couple of hours, pretty much as per speedtest....
apjashley1
my SamKnows box came today too Smiley
Unfortunately it doesn't support 5GHz networks so if the tests run while I'm using my iPad they'll be inaccurate.
maxm4xww
How do you go about getting one of these then? All I can see is 'How to buy'?
w23
Fixes: 4
Try https://www.samknows.eu/
Call me 'w23'
