Apple iPad 2
- Re: Apple iPad 2
Apple iPad 2
25-01-2015 11:25 AM
I am thinking of getting the Apple iPad Air2 I noticed that Amazon is about £40 cheaper but I am worried if there was a problem with it sending it back or it could be easier to walk into a Apple store for better attention.
4 REPLIES 4
Re: Apple iPad 2
25-01-2015 12:12 PM
Apple products comes with a 12 month manufacturer's warranty. Any issues, just take it to the Apple Store and they'll fix it there and then or give you a replacement.
Re: Apple iPad 2
25-01-2015 1:52 PM
'Not a lot of people know this,' but it's worth remembering just in case one or two suppliers turn out to be a bit forgetful!
Re: Apple iPad 2
26-01-2015 8:11 PM
I purchased a Dyson from Currys and developed a fault.
Tried to return it to Currys along with receipt and box etc... Said no and contact the manufacturer.
Called Dyson and said Currys should replace it FOC. Went back and told them about the EU 2 year returns thing and they said it's the manufacturer. I demanded to speak to the supervisor/manager and they eventually shelled out and replaced it.
I would say Currys are the worst at returns on faulty items.
NE
NE
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up
Re: Apple iPad 2
28-01-2015 4:38 PM
Quote from: JayG 'Not a lot of people know this,' but it's worth remembering just in case one or two suppliers turn out to be a bit forgetful!
Errr.... not quite correct see http://blog.moneysavingexpert.com/2010/12/13/the-eu-goods-must-last-a-minimum-two-years-rule-is-a-my...
Kevin.
