Apple iBeacon Tracking Now Works Even When Shopping App Turned Off
TORPC
[quote=http://guardianlv.com/2014/04/apple-ibeacon-tracking-now-works-even-when-shopping-app-turned-off/]iBeacon: the Apple Bluetooth system that can track an iOS device such as an iPad or iPhone through a marketer’s app. For example, stores, stadiums, malls, and museum apps use the iBeacon technology so that the store can track a customer’s movements and send them information. What most users are not aware of is that thanks to iBeacon technology and that latest iOS7 upgrade, the device can be tracked even when the app is not running.
7 REPLIES 7
godsell4
Re: Apple iBeacon Tracking Now Works Even When Shopping App Turned Off
The point is, for ibeacon and passbook to be useful, this is how it needs to work.
And if you think ibeacon is the only way your iOS or Android device is capable of being tracked then the author of the article is very naive.
3Mb FTTC
TORPC
I know it is only 1 of many ways to be tracked, therefore (I DO NOT need to THINK)
Not to be seemingly taking side(s) with the author
she might of been sticking to the point, & not going off an a tangent by dragging old news into the report
Just my observation......
VileReynard
Fixes: 20
Leave your mobile at home before going shopping.
TORPC
Then @ what point & good is a mobile device, if left @ home
VileReynard
Fixes: 20
If someone needs to talk at you, it will keep until you get home.
TORPC
Can you define your meaning of Needs
Look at the actual verb for the word needs
Here you go
What happens if it is a family emergency, or urgent support to keep client(s) ticking over, so one can pay the bills, et al
One can not afford to leave mobile at home
VileReynard
Fixes: 20
National Exchange for Egg Donation and Surrogacy (NEEDS)
Grin Grin Cheesy Grin Grin
