Apple base stations
NorthEasterner
Apple base stations
I'm planning on buying a few Apple extreme base stations A1034 (I know they are old and run on WiFi G) but the house is small and  range will be covered.
I am planning to buy an Apple express base station the new gen or an extreme base station.
My question is, will I be able to pair the 2 together and create a network where I can extend my WiFi and set up speakers using AirPlay?
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up Thumbs_Up
