Apple Extreme or Apple Time Capsule?
NorthEasterner
I'm looking at getting a Apple Time Capsule or an Apple Extreme.
Apple Time Capsule £249
Apple Extreme £169
If I add a hard drive to Apple Extreme, is it just basically the same features as Time Capsule?
NE
Ex Plusnet Fibre customer. BT Infinity Customer using a BT Smart Hub. If you wish to say thanks, please click the thumbs up Thumbs Up
Fixes: 224
Re: Apple Extreme or Apple Time Capsule?
Quote from: NorthEasterner
yup, that's what I've done, less aesthetically pleasing but cheaper and more practical.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Am thinking about doing something similar, using an Airport Stream plus a USB HDD, will Time Machine backup an OSX machine to this HDD the same way as if it were a Time Capsule?
3Mb FTTC
Fixes: 224
Assume you mean an extreme? If so,  Yes, I've plugged a 4TB drive (cost less than the difference between an extreme and time capsule) and have 4 macs backing up to it regularly.
Thanks, think I will go that route.
3Mb FTTC
Fixes: 224
i have also successfully done a full restore and also individual file restores with no problems.
NorthEasterner
Think I'll go this route as well and attach a 1tb drive since we only have 2 macs.
Can you access content stored on hard drive on iPads  and iPhones?
