Apple App Store running slow.
FIXED- Subscribe to RSS Feed
- Apple App Store running slow.
- « Previous
- 1
- 2
- Next »
Re: Apple App Store running slow.
07-03-2017 9:01 AM
@scrookes - This is still not working for me as eventually when the App Store does load and I find the application or even using the link directly to load it in App Store it takes ages. When viewed in the App Store I get this:
If I then select it for installation I get this:
The fact that this application does not install is of no consequence now, as I used the Windows version on a VM, but the fact remains there are evidently issues with the App Store. What the cause of these are I cannot say, but I would like to see it fixed.
07-03-2017 10:17 AM
Fixed it. I had a temp test Proxy set for HTTP set and on removing this everything is as it should be. Note to self, pay attention to your notes, they are written for a reason!
- « Previous
- 1
- 2
- Next »
