Apple Airport Express
- Apple Airport Express
16-10-2015 4:44 PM
Re: Apple Airport Express
16-10-2015 5:46 PM
you need to connect to the another device.
for FTTC that would be the OR modem.
for ADSL it would be another device doing the actual DSL connection.
16-10-2015 5:49 PM
16-10-2015 5:52 PM
16-10-2015 5:56 PM
Thinking of this with the OR modem rather than a all in one box
16-10-2015 5:58 PM
16-10-2015 6:02 PM
16-10-2015 6:30 PM
16-10-2015 6:57 PM
16-10-2015 7:22 PM
unless the standard extreme now has the HDD inside as standard.
16-10-2015 7:42 PM
16-10-2015 7:45 PM
the config tool for the AEBS is a but clunky (was the last time i used one), there is web UI for them so you can't manage them via a webpage like you can with just about every other router.
16-10-2015 7:50 PM
16-10-2015 8:43 PM
16-10-2015 8:48 PM
Am thinking it to do with when neighbours are home around the close and more wifi active so cause problems? so a dual band router would help/.
