Apple AirPlay choppy and laggy
Ritch666
AirPlay movies when played from MacBook are laggy and choppy. (But strangely fine from iPads and iPhones) Apparently turning off WMM in the QoS settings can solve this issue. However after speaking with plus net it is not possible to do this on the plus net technicolor router. Does anybody know of a workaround?
Ritch
howiemartinez
Re: Apple AirPlay choppy and laggy
I would like an answer to this too please
howiemartinez
Had the same issues, but the only workaround I've found (using the PN route/modem) is to connect Apple TV direct to the router via ethernet. It's messy (more wires), but it works.
