Anyone used Window's 'Fix It' software?
randpwar
I use Vista, but nothing 'techie' in any way so it does the job for me.  Is this worth bothering with?
http://news.bbc.co.uk/1/hi/technology/8629331.stm
Fixes: 62
Re: Anyone used Window's 'Fix It' software?
Hasn't found a solution when Crysis crashes in Windows 7 (the actual solution is to turn down the quality settings)
Denzil
It is built in to W7, and I have yet to see it actually come up with a solution to anything Grin.
The software has onboard fixes for about 300 of the most widely encountered problems that stop Windows working as it should.
OK, but that is a drop in the ocean of the problems that stop Windows working as it should.
