Anyone running Internet Explorer 5.5 or 6?
MikeWhitehead
If you're running IE prior to version 7, I'd like some help.
http://mir.hamcall.co.uk/test.html
http://mir.hamcall.co.uk/test2.html
Could you tell me how the two images display on your screen? It should be that test.html doesn't display the transparency correctly, and test2.html does.
Thanks in advance Smiley
Fixes: 5
Re: Anyone running Internet Explorer 5.5 or 6?
neither do in IE6.0.29
Kelly Dorset
Broadband Service Manager
MikeWhitehead
Might have fixed it, anyone is welcome to test it again Tongue Thanks.
Fixes: 5
Nope Sad
Kelly Dorset
MikeWhitehead
*Cries*
How about now? lol.
MikeWhitehead
Yea, the problem is that prior to IE7, IE didn't display PNG transparency correctly, which is a huge headache for designers. I'm testing a behaviour file to see I could use that to alter how it's displayed, but it seems that it isn't working as yet Sad
Thanks for everyones help so far.
Could it have something to do with the fact that your HTML says:
style1/pngbehavior.htc
which 404s as the file on your server is spelt correctly with the u ;-)
MikeWhitehead
Haha, omg...I'll check that now. Roll eyes
EDIT: Although it WAS pointing to the wrong place, it's still not doing what it should (I've managed to get hold of a laptop with IE6 on so testing between the two now).
MikeWhitehead
Managed to fix it (more or less) with some PHP trickery.
Thanks for those who helped Smiley
jaythe0ne
Works on my Win 2000 machine with IE 6.0.0028
MikeWhitehead
Quote from: jaythe0ne
Does it display without the white background? and if so, which page works?
jaythe0ne
heh, now neither are working, just getting cannot find page. sorry.
MikeWhitehead
Sorry, I forgot I asked you which worked and deleted the pages Tongue
Mod can delete this thread to clean the place up a bit if they like Smiley
Thanks all.
