Anyone running Internet Explorer 5.5 or 6?
- Re: Anyone running Internet Explorer 5.5 or 6?
18-09-2007 12:18 PM
http://mir.hamcall.co.uk/test.html
http://mir.hamcall.co.uk/test2.html
Could you tell me how the two images display on your screen? It should be that test.html doesn't display the transparency correctly, and test2.html does.
Thanks in advance
18-09-2007 12:34 PM
Ex-Broadband Service Manager
18-09-2007 12:54 PM
18-09-2007 1:00 PM
18-09-2007 1:04 PM
How about now? lol.
18-09-2007 1:47 PM
Thanks for everyones help so far.
18-09-2007 1:53 PM
style1/pngbehavior.htc
which 404s as the file on your server is spelt correctly with the u 😉
18-09-2007 2:02 PM
EDIT: Although it WAS pointing to the wrong place, it's still not doing what it should (I've managed to get hold of a laptop with IE6 on so testing between the two now).
18-09-2007 3:38 PM
Thanks for those who helped
18-09-2007 5:28 PM
18-09-2007 7:12 PM
Quote from: jaythe0ne Works on my Win 2000 machine with IE 6.0.0028
Does it display without the white background? and if so, which page works?
20-09-2007 10:12 AM
20-09-2007 10:13 AM
Quote from: jaythe0ne heh, now neither are working, just getting cannot find page. sorry.
Sorry, I forgot I asked you which worked and deleted the pages
Mod can delete this thread to clean the place up a bit if they like
Thanks all.
