Anyone got any ideas on this PC issue I have?
Moominfish
Re: Anyone got any ideas on this PC issue I have?
No probs mate.
And oldjim, really? If any problems then the card would/should be returned to Scan as it states it's got a 24 month return to base warranty, the base being Scan, they would have to replace the card and send the faulty 1 back to XFX, also I can tell you the XFX support isn't bad at all if you go directly to XFX (which you shouldn't do if the warranty is with Scan for the 1st 24 months as stated on the product page for thet XFX gfx card Paul) I had several responses in one day from a customer service rep on the XFX site for a fault I experienced with one their 850 watt psu's.
