Anyone else having issues with Tesco bank logins?
Fixes: 21
I have used online banking for several years with no problems, went to log in to day and it is just sitting there saying "Detecting browser settings"
Their "help" shows M$ & Mac browsers but of course no Linux ones.
This is in FF 19.
Fixes: 21
Re: Anyone else having issues with Tesco bank logins?
Works in Opera though  Crazy
VileReynard
All Star
Fixes: 11
It appears to work correctly in Firefox 20 in Mint 13 (although obviously I'm not going to register).
Fixes: 21
Must be one of my many addons then. Not updated to 20 yet, did you side load it or from a ppa?
VileReynard
All Star
Fixes: 11
It was supplied as a standard update in Mint 13 - probably from Ubuntu.
The package is "20.0+build1-0ubuntu0.12.04.3" in precise-updates.
Fixes: 21
Not in mine, strange that. Still running v19 under Mint 13 Mate edition.
Mind you I have the U update stuff disabled. (After it broke my wine install)
EDIT:
OK just checked my update sources and for some reason I had disabled the "recommended & critical" updates  Lips are sealed Undecided
167Mb to download and FF20 is amongst it.
Thanks mate. Wondered why I hadn't had any updates for a while  Grin
