Anybody know where to get
- Anybody know where to get
21-08-2017 9:49 AM
a micro usb to micro usb cable (male to male)?
I want to connect a Pi Zero to an Wemos D1.
I can find micro usb to virtually everything else bar another micro usb, HDMI, mini usb, etc etc.
Or do I have to butcher a normal cable?
Re: Anybody know where to get
21-08-2017 9:52 AM
Is this what you are after?
21-08-2017 9:55 AM
What about one of these:
https://www.uk.insight.com/en-gb/productinfo/usb-cables/0005382787-00000001
21-08-2017 10:35 AM
When you can get a usb->micro for a quid why is the micro-micro 3x the cost?
21-08-2017 11:27 AM
@HairyMcbiker wrote:
...why is the micro-micro 3x the cost?
Lower production volume?
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
22-08-2017 10:42 AM
@HairyMcbiker Not quite what you asked for, but what about one of these (ships from HK), or this, a cheaper version.
They look similar in function to the convertor that was supplied with my Samsung phone.
22-08-2017 10:59 AM
But China doesn't seem to mass produce them like it does for normal usb->micro cables.
Will probably just cut the end of one and solder a micro-usb plug on the end, got some of them laying about.
22-08-2017 11:09 AM
They are the idea, a longer one would have been better, and preferably without the 100% delivery charge on the insight one.
I'd imagine they sell a lot less of those than the usb->micro, so the production costs are higher.
22-08-2017 12:05 PM
22-08-2017 3:44 PM
maybe something there that fits your price range
22-08-2017 6:26 PM
These searches seem to ignore what you are imputing and look for individual names rather than "micro usb to micro usb" as requested, even with "'s on them. (Same on Aliexpress)
22-08-2017 6:34 PM
yes but the top 3 items in that search are exactly what your referring to micro b to micro b synch /charge leads http://www.ebay.co.uk/itm/2m-USB-Micro-B-Male-To-Micro-B-Male-Charger-Cable-Lead-Smartphone-Data-Syn... a 2m long one for instance
22-08-2017 6:59 PM
not when I look at it?
I see
Again £4 for a bloody cable! (your last link)
I will just get the soldering iron out.
22-08-2017 7:03 PM
23-08-2017 10:07 AM
But @£4 I will just make one. That way I can make it as long as I need it. (TBD)
