Anybody know where to get
HairyMcbiker
All Star
Fixes: 21
a micro usb to micro usb cable (male to male)?
I want to connect a Pi Zero to an Wemos D1.
I can find micro usb to virtually everything else bar another micro usb, HDMI, mini usb, etc etc.
Or do I have to butcher a normal cable?
14 REPLIES 14
Re: Anybody know where to get
Is this what you are after?
https://www.amazon.co.uk/dp/B018M8YEX0/
mikelahey
Fixes: 12
HairyMcbiker
All Star
Fixes: 21
They are the idea, a longer one would have been better, and preferably without the 100% delivery charge on the insight one.
When you can get a usb->micro for a quid why is the micro-micro 3x the cost?
198kHz
Fixes: 41
@HairyMcbiker wrote:
...why is the micro-micro 3x the cost?
Lower production volume?
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
RobPN
Fixes: 13
@HairyMcbiker Not quite what you asked for, but what about one of these (ships from HK), or this, a cheaper version.
They look similar in function to the convertor that was supplied with my Samsung phone.
HairyMcbiker
All Star
Fixes: 21
@RobPN I already have a OTG cable which is basically what they are, but wanted to make it neater.
But China doesn't seem to mass produce them like it does for normal usb->micro cables.
Will probably just cut the end of one and solder a micro-usb plug on the end, got some of them laying about.
Alex
Fixes: 13
I'd imagine they sell a lot less of those than the usb->micro, so the production costs are higher.
HairyMcbiker
All Star
Fixes: 21
probably but I think they maybe getting more common now, with more and more equipment using micro usb as standard.
nanotm
https://www.ebay.co.uk/sch/i.html?_odkw=micro+usb+male+to+male+data+lead+cable&_osacat=0&_from=R40&_...
maybe something there that fits your price range
HairyMcbiker
All Star
Fixes: 21
@nanotm been there and looked, all seem to be the micro-mini versions (or standard usb-micro)
These searches seem to ignore what you are imputing and look for individual names rather than "micro usb to micro usb" as requested, even with "'s on them. (Same on Aliexpress)
nanotm
yes but the top 3 items in that search are exactly what your referring to micro b to micro b synch /charge leads http://www.ebay.co.uk/itm/2m-USB-Micro-B-Male-To-Micro-B-Male-Charger-Cable-Lead-Smartphone-Data-Syn... a 2m long one for instance
HairyMcbiker
All Star
Fixes: 21
not when I look at it?
Again £4 for a bloody cable! (your last link)
I will just get the soldering iron out.
Browni
Aspiring Hero
Fixes: 60
This is what I get
HairyMcbiker
All Star
Fixes: 21
I meant your first link to the search, not the 2nd to the item.
But @£4 I will just make one. That way I can make it as long as I need it. (TBD)
